Help?! Audio disabled?? ASAP?
RockIt
I was attempting to disable my microphone on my HP windows vista, and I disabled all of my sound! I've read around all over online and all I found was to right click on the speaker on the task bar at the bottom of the screen and right click in white space and click on disabled/disconnected devices. I did and nothing shows up still?
HELP?
In advance, thank you.
go in your device manager. Look for anything disabled. If you did manage to disable the sound card itself it would remove it from other locations to click on.
    Homebrew
    Intel Pentium D 3ghz
    Intel D945GNT
    4x 1gb Crucial dimms
    EVGA nVidia 8800 GTS 512mb
    Soundblaster Audigy Fatality Champion series w/ front panel
    Samsung Syncmaster 225BW
    16080x1050
    Seagate Sata's 750gb 250gb 250gb 250gb 120gb external 80gb usb 300gb usb 300gb usb 500gb esata
    1000w thermaltake
    Grey with a Dragon window :)
    5x 6 inch case fans and 2 120mm psu fans
    Logitech G5
    Logitech G15
    16mbps down,/ 1mbps up Cable
    Logitech x-530 speakers Xbox Wireless controller
