Airbot
Creative Sound Blaster Audigy series driver 2.18.0017
Information
Release date : 9 Apr 10
This download is a driver providing Microsoft® Windows® 7, Windows Vista® and Windows XP support for Creative Sound Blaster® Audigy® series of audio devices. For more details, read the rest of this web release note.
Fixes:
Resolves the following issues:
Information
This download supports the following audio devices only:
Creative Worldwide Support
Fixes:
- Audio device driver files are not removed completely when uninstalling from Windows Device Manager.
- Sound Blaster Audigy audio device does not appear in the Encoder tab of Audio Control Panel.
- Unable to run 64-bit version of ASIO software.
- Device error caused by enabling audio enhancements.
- Incorrect speaker configuration shown in Audio Control Panel.
- System unable to shut down when Dolby® Digital Live is enabled in Windows 7.
- Passthrough of Dolby/DTS® audio does not work with Windows Media Player 12 in Windows 7.
- Speaker settings in Audio Control Panel are not in sync with Microsoft Speaker Setup in Windows 7 64-bit.
- System becomes unstable when uninstalling the audio device driver in Windows 7 64-bit.
- Sound Blaster Audigy including Platinum and Platinum eX series
- Sound Blaster Audigy 2 including Platinum, Platinum eX, and Value series
- Sound Blaster Audigy 2 ZS including Platinum and Platinum Pro series
- Sound Blaster Audigy 4 Pro and Sound Blaster Audigy 4
- Sound Blaster Audigy 2 ZS Notebook PCMCIA
- Airbot 2.0
- Core i7 920 (D0) @ 4Ghz, 26c idle- 65c full load on air
- Asus P6X58D Premium -Sata 6Gb/s - USB 3.0
- 12GB Corsair Dominator -CMD12GX3M6A1600C8
- EVGA Nvidia GTX 480 -Fermi
- ASUS Xonar D2X
- LG 24" Flatron W2453V-PF Full HD 1080p 2ms response time
- 1920x1080@60hz
- 1 OCZ Vertex2 180GB SSD 1 TB Samsung Spinpoint F1 7200RPM 32MB cache 2 500GB WD Caviar Blacks 7200RPM 32MB cache (WD5001AALS) Pioneer DVD Burner DVR-S18M
- PSU
- Corsair HX1000W
- Case
- Cooler Master HAF 932
- Cooling
- Case Fans -3 230mm, 1 140mm/CPU - Tuniq Tower 120 Extreme
- Logitech Wireless MK700
- 100 MBPS DL 30.17Mbps UL 0.98Mbps
- Other Info
- Windows 7 Processor-7.7 RAM- 7.9 Graphics-7.9 Gaming Graphics- 7.9 HDD- 7.8 W.E.I final score= 7.7 Windows Vista=5.9
