Vista Keeps playing the "lock" sound
ProudToBeNerdy
This might not be the right board for this, but my Compaq Presario F700 keeps playing the "Exit Windows" sound (Windows Shutdown.wav) seemingly at random intervals. It's not that dire but it does get really annoying:confused:. Any ideas?
    Compaq Presario F765EA
    1983MB
It's random, you say? Are you disconnecting USB things like thumb drives alot?
You could go into "Sound" off a typed-in prompt from the Start Menu's search bar and hunt down the Windows activity that's making that sound. It's the Windows Logoff Sound.wav you're looking for.
    Hewlett-Packard dv6936us
    Intel Core 2 Duo "Merom" T5750, 2 GHz, stock clocking
    stock Quanta 30D2, v.792E
    4 GHz, 667 MHz bus speed
    NVIDIA GeForce 8400M GS, stock
    stock Realtek software-based
    stock 15.4" widescreen
    stock 1280 X 800
    stock Toshiba MK2546GSX and a Western Digital 1TB MyBook
    stock
    stock
    stock plus Rocketfish model RF-LAPCOL
    stock Synaptics Pointing Device
    stock
    Ludicrous Speed (~10.9 Mbps, more or less)
    Browser: Namoroka v1.9.2.3666 64-bit build. Computer specs: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01485288&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3747246 I like chocolate milk!
Well, I have been using a USB pen drive a lot recently, but I am sure that it is the "Shut Down" sound, this one, as opposed to the "connect" or "diconnect" sounds. It's not the lock sound actually, I realised that at the last moment and forgot to change the post title, sorry.
    1983MB
Paulie's advice still stands.
Go to Control Panel > Sound, Sounds tab, and check which sounds are associated with the various events in Windows.
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
I understand that; I don't want to KNOW what sound is playing, I want to know how to stop it from playing so frequently. And if you mean that I should disable the sound completely, that seems a bit drastic.
    1983MB
No, I don't mean disable all sound.
If you find the entry that's causing the sound to be playing in Control Panel > Sound, you can change that entry only to stop playing a sound, or a different one if you want.
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Any luck?
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
A list of your running applications, and a list of processes running under the localname *your Vista account name*, would be timely to help us address this matter.
    stock 1280 X 800
    stock
    stock
    stock
I feel like an idiot now :o You see, I've found out what the problem is; I use Google Chrome, and I have an extension called Google Mail Checker that checks my email automatically. I didn't realise it plays a sound automatically when mail is received. I apologize, I've been such an idiot.
    1983MB
S'all good!
    stock 1280 X 800
    stock
    stock
    stock
