S
s660117
I am experiencing what seems to be a common problem, but am opening a new post on the chance that I have missed something in the other posts that I've read. I am running Vista 64 bit Home premium and have an Audigy SE sound card installed. Suddenly, after a reboot, I have no sound at all. The system recognizes the sound card and the system information on it follows --
Name SB Audigy
Manufacturer Creative Technology Ltd.
Status OK
PNP Device ID PCI\VEN_1102&DEV_0007&SUBSYS_100A1102&REV_00\4&237A0637&0&10F0
I/O Port 0x0000EC00-0x0000EC1F
IRQ Channel IRQ 19
Driver c:\windows\system32\drivers\p17.sys (5.12.1.2020, 1.25 MB (1,309,696 bytes), 10/16/2009 7:44 AM)
The device was uninstalled and reinstalled, with the same 5.12.1.202 driver, but there is still no sound at all - not only will it not play an MP3 file, but there are no system sounds either. Dual boot is set up and sound works fine under suse. If a song is played, the volume mixer shows activity and if I test the speakers from Device Manager, it also shows activity. I just don't get any sound.
I have the onboard sound disabled and have deselected the option that allows an application to take exclusive control of the device.
Thanks in advance,
s660117
Name SB Audigy
Status OK
IRQ Channel IRQ 19
Thanks in advance,
s660117
