Windows Audio Stopped Working
ravipe007
I have a notebook HP Pavilion DV5-1159SE and now I'm getting a "Windows Audio Stopped Working" message. Here's the problem:
Problem signature:
Problem Event Name: APPCRASH
Application Name: svchost.exe_AudioSrv
Application Version: 6.0.6001.18000
Application Timestamp: 47919291
Fault Module Name: stapo64.dll
Fault Module Version: 1.0.6225.0
Fault Module Timestamp: 4a664604
Exception Code: c0000005
Exception Offset: 000000000012e3cc
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1046
Additional Information 1: 0a71
Additional Information 2: 2b9e64833ded1b8566df2c12e9bbc072
Additional Information 3: 9c1e
Additional Information 4: 07250e8aa3e8a202ef2ff229b5ce3c93
Read our privacy statement:
Microsoft Online Crash Analysis
I'm also getting the same message but now about the "DHCP Stopped Working". I'll post the issue as soon as I get the message again.
Please somebody help me! I already tried to install codecs from various codeck packs (K-Lite, Vista, etc) but none of them worked. And I only install system updates from Microsoft Update program which is automatic on my notebook. Btw my OS is a Windows Vista Home Premium 64bit SP2 ok? Thanks in advance!
Restart the service, and you may have to reinstall your audio drivers if any.
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
Did you ever have any success at fixing this? I've been having the same problem for a while now. Would you be running AVG free by any chance?
    Dell INspiron
    1366x768
    Logitech trackball
    10Mb/s
Go to start type services.msc go to Windows Audio see if that is set to auto start. Start it if it has stopped.
Highlight it,Right Click.go to Properties,in the start up box set it to automatic
then press OK.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Mine is already set to automatic. The problem is something keeps killing it not that it isn't started to begin with. I poked around today and disabled AVG Free and turned on a different AV. So far, i haven't had any problems that's why i was asking earlier.
    Dell INspiron
    1366x768
    Logitech trackball
    10Mb/s
yes my post was not for you it was for the thread starter.
    LENOVO 64734VM
    15 inch
@ilikefree Okay sorry bout that.
Anyway, after about two days of not having audio die it did it again, so that rules out AVG. I haven't noticed any pattern so far. Changing the track in WMP causes it, loading videos in VLC, debugging xna projects, and loading video games. The only real thing they have in common is that they use the sound card. I'll try and be more careful about taking notes as to exactly what im doing when it crashes.
    Dell INspiron
    1366x768
    Logitech trackball
    10Mb/s
Go to Computer, Right click,Manage,expand System Tools,click Event Viewer,
Look here for error messages from the time it happened.
    LENOVO 64734VM
    15 inch
