Left and Right Audio Swapped
ronrontiu
I just noticed that the audio from the left comes from the right speaker and vice-versa. This happens randomly and the problem suddenly disappears. The problem is happening again and I don't know how to swap the two speakers. A restart will temporarily fix the problem but later on it gets swapped again. I can't switch the position of the speakers because this is a laptop. This gets very annoying when I'm playing games such as CS. Anyway to solve this?
    Athlon 250 @ 3Ghz
    ECS 6100pm
    2GB DDR2
    9800gt Inno3d Green
    1366 x 768
This is quite possibly a driver issue. Have you got the latest audio driver installed? What is the make and full model number of your laptop?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Well it just fixed itself again. My laptop is a Fujitsu L1010
    Athlon 250 @ 3Ghz
    ECS 6100pm
    2GB DDR2
    9800gt Inno3d Green
    1366 x 768
Does it happen only in a particlular program, or it occur everywhere? It could be the fault in some specific program settings then.
    HP tx2001au Entertainment Notebook PC
    AMD Turion TL-58 64x2, 1.9 GHz
    2GB
    nVidia GeForce 6150 Go (128 MB)
    Hitachi 150 GB
It happens at random times, during random programs
    Athlon 250 @ 3Ghz
    ECS 6100pm
    2GB DDR2
    9800gt Inno3d Green
    1366 x 768
Oh, if that's the case, it's something completely different from what I had in mind.
Just try reinstalling the sound card/speaker drivers. It may just do the job.
    2GB
    Hitachi 150 GB
