USB Headset Vs Sound Card?
majicninja
PC Gamer
I recently switched from using an analog headset to a USB headset. Everything works great but when I want to listen to music in a chat room or something like that i dont have an option on the USB headset to switch to stereo mix at all. The soundcard states that stereomix is working but when i switch it over no one can hear the music or they say it sounds like crap....is there a driver for this that i can install manually?
My headset is the Plantronics Gamecom 777 5.1 Surround USB Headset.
Their webpage does not have drivers and the headset did not come with a disk.
    Powered By Asus Built By Me
    AMD Athlon II 250 Regor 3.0GHz
    AsusTek M3A76-CM
    2x 2048MB DDR2 PC6400 OCZ High Performance Gold Edition @ 2.1v
    ECS Geforce GTS 250 512MB
    Via Onboard
    Acer X203H Compaq FS740
    Acer-1600x900 Compaq 1280x1024
    Seagate Barracuda 250GB 7200 RPM Western Digital Caviar 80 GB 7200 RPM
    A-Power 680 Watt PSU
    Power Up Micro ATX Case
    1x 120mm Case Fan 1x 80mm Case Fan
    OCZ Equalizer 7 Button Laser Gaming Mouse
    Microsoft Comfort Curve Ergonomic Keyboard
    6Mbps
    1x 1024 PNY Flash Drive Integrated In Windows ReadyBoost.
