Sound works, and sometimes it doesn't.
sonicroxs
Hello,
I have been having this problem, which is that sometimes, my sound is working, and sometimes it is not. It usually starts working after my PC has been off for a long period of time (for example, when I wake up). Oh, and if this helps, my soundcard is a Realtek HD card.
Any help?
    Acer Aspire 5520
    AMD Turion 64 X2 Mobile TL-58
    Acer Fuquene (Socket A)
    3.0GB Single-Channel DDR2 @ 320MHz 5-5-5-15
    nVIDIA GeForce 7000m
    Realtek HD
    250GB Western Digital WDC WD2500BEVS-22UST0 ATA Device
    50mbps Wireless
Hello sonicroxs,
It sounds like something is getting hot, do you have any temp monitoring software installed ?, i would look at a heat issue first.
Take a look and post your results, good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Well I just woke up and strangely my sound isn't working. BTW, my GPU is at 67ºC, my Hard Drive is at 25ºC, and the core temperature is at 35ºC.
    Acer Aspire 5520
    Realtek HD
    50mbps Wireless
Try going to the Device Manager and un-installing the sound driver, reboot and re-install.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
That's the problem. The driver only appears in the Device Manager when the sound is working. At the moment, it isn't working, so I can't reinstall.
    Acer Aspire 5520
    Realtek HD
    50mbps Wireless
Go to the makers site and install the latest sound driver, also, while you are there, install the latest chipset drivers too.
Do the chipset drivers first.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Woohoo! I reinstalled my chipset drivers and my sound started working! For now...
In 24 hours i'll report if my sound stops working.
    Acer Aspire 5520
    Realtek HD
    50mbps Wireless
Fingers crossed here. :)
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Ok, my sound is working :D Thanks for the advice.
You may lock this thread now.
    Acer Aspire 5520
    Realtek HD
    50mbps Wireless
Glad it worked out for you. good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
