Vista sounds stopped working
dannom
Im running vista home on my tosh laptop. Suddenly windows sounds have stopped working, when you click on the speaker icon bottom right it not longer makes that annoying sound also youtube doesnt play sound etc.
Sound does still work in media player though, i can still listen to cd's.
anyone have a clue, very fustrating.
drivers installed are realtek high definition audio 6.0.1.5326 17/11/2006.
Left-click that little speaker icon on the bottom right.
Click on "mixer."
The various open "Applications" should all have the same levels or however you want them. Experiment with the faders to see how they work; they actually work really well for keeping your specified settings across applications.
    Hewlett-Packard dv6936us
    Intel Core 2 Duo "Merom" T5750, 2 GHz, stock clocking
    stock Quanta 30D2, v.792E
    4 GHz, 667 MHz bus speed
    NVIDIA GeForce 8400M GS, stock
    stock Realtek software-based
    stock 15.4" widescreen
    stock 1280 X 800
    stock Toshiba MK2546GSX and a Western Digital 1TB MyBook
    stock
    stock
    stock plus Rocketfish model RF-LAPCOL
    stock Synaptics Pointing Device
    stock
    Ludicrous Speed (~10.9 Mbps, more or less)
    Browser: Namoroka v1.9.2.3666 64-bit build. Computer specs: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01485288&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3747246 I like chocolate milk!
Hello ,
I am new here and hope to fit in . Now to my ? , I have the same problem as the OP and all I can add is that my wife's profile plays all sounds normally . I have tried all the above mentioned fixes and even went as far as trying to set up a new profile and copy old one to it...still won't work . I know it is something in my profile , but can't figure it out . I don't want to reinstall Vista , but.....any help would be greatly appreciated , thanks in advance ,
Ken
