Speakers: Realtek High Definition Audio not plugged in
lisa0922
Hey! I am desperate for help, my sound stopped working suddenly - I don't even get the windows start-up sound anymore. I have tried upating drivers and that did not work, i think i see my problem: I have attached a capture of my sound screen from the control panel. It says my speakers are not plugged in but i use an HDMI cable to my monitor which is also my speakers and my monitor works fine.
THANKS!!!
    HP M9177C
    Realtek High Definition Sound
Hello lisa0922,
Can you go to Device Manager, and check to see if there are any yellow triangles anywhere.
Take a look and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hey Stoneys-nutz!!!
The only triangles are under network adapters, not sound.
    HP M9177C
Try going to Device Manager and un-installing the sound drivers, reboot and Vista will re-install the drivers.
Your sound card could be broken, but it would be rare if it was.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I've tried that already, I even read about un installing, rebooting, uninstalling again and then downloading the drivers from the realtek wesite but even that didn't work!
    HP M9177C
Do you have another set of speakers you can try, check all the connections, both outside and inside the case, also, check that there is nothing muted, and check the volume control, i know, your thinking volume control ?, is he mad, but you would be surprised at the things we come across here.
Is the sound card on the Motherboard, or on a separate card ?. If it is a PCI card, try re-seating it.
How do the speakers connect to the PC ?.
Has the PC been moved recently ?.
Have you installed/un-installed any hardware/software recently ?.
These are all things you have probably done, but just recheck everything.
If you have checked everything, and its still not working, then you need to consider the sound card itself.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Omg I was so fed up. I thought my integrated sound on my motherboad had went out too. Try unstalling updating nothing work. Even tried disabling front panel sound or whatever.
Saw on many forums but no one seems to had a fix. Im sure I just didnt look hard enough haha. Anyways I didnt want to go installing everything again like my motherboard drivers.
All I did was flashed back my bios on my motherboard (factory settings) and boom the Realtek sound icon and everything was back to normal. I got sound again. :))))
