Solved Headphones simply dont work
louisg7594
I have a compaq CQ60, its 6 months old and when I plug the headphones nothing happens, I have also noticed that the built in microphone doesn't work either. What shall I do?
Welcome,
Go to control panel, hardware and sound, manage audio devices.
Make sure they are listed there and are not disabled.
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
I plug my headphones and it recognizes them, but the speakers are still on and nothing happens to the headphones, the built in microphone is also listed there but it doesn't record anything... i think this is some sort of malfunction shall, I send it to Compaq to get it fixed?
    Asrock P67 Extreme4
    auria eq2367
Thanks, I contacted them and they told me to update some drivers and now everything works fine
You're Welcome, Glad you got it working.:)
    Asrock P67 Extreme4
    auria eq2367
