Hi All
My TECHNIKA autofocus webcam with built in microphone was easy to set up and the picture is ok - seems a bit in slow motion - but the microphone is out of sync
with the recording and playback.
I have tried asking this on many sites, but since I have Vista I though one of you clever bods would have some idea. It is very frustrating.
The webcam is: Technika 1.3 Webcam model no: H16BD5 from Tesco. Frame rate 30 frames per second at 640x480 resolution, built in microphone, plug and play, no need to install software.
My PC is an Acer Aspire M3600 - Inel Core 2Duo cU E4500 @ 2.20GHz 2.20Ghz, 2GB Ram.
Any help would be appreciated.
Thank You!
Thank You!
