Mkyruvesta
. . . into the headphone jack to record? I've done this and I've found that the mic is able to pic up sounds from a greater distance than if I just plugged it into the mic.
I'm not sure why it does that but I do find it helpful in some cases. Why does it do that, and it doesn't damage the computer does it?
- Hewlitt-Packard
- AMD Turion(tm) X2 Dual-Core Mobile RM-72 2.10 GHz
- 3 GB
