You should upgrade or use an
alternative browser .
Solved How to remove empty Vol. mixer bars?
same situation as in the picture:
why is it & how to remove it?
LENOVO G-530
# Intel Pentium Dual-Core T3400 (2.16GHz, 1MB L2 cache, 667MHz FSB)
# 15.4-inch glossy 16:10 display (1280x800)
# Intel Graphics Media Accelerator 4500MHD
# 3GB DDR2 667MHz RAM
# 250GB 5400RPM HDD
# SuperMulti DVD+/-RW Optical Drive
# Broadcom WiFi (802.11b/g), 10/100 Ethernet, Modem
# 6-Cell 11.1V 53WHr Battery
http://www.notebookreview.com/default.asp?newsID=5022&review=lenovo+g530
Hello Prukeyhi, and welcome to Vista Forums.
What do you mean, and remove what?
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Thanks!
well the empty space on the volume mixer window-why is it ?
i tried to resize it as well -but upon reopening it becomes large again.
Thats the normal size it should be:
LENOVO G-530
# 250GB 5400RPM HDD
It's that size by default for your available default "Volume Mixers". It cannot be changed as far as I know of.
Operating System
Operating System
what do you mean available default "Volume Mixers" ? on both pictures there are only 2 applications- why the 1st is larger then the other?
LENOVO G-530
# 250GB 5400RPM HDD
Sorry, I meant any future available ones. For example, a microphone, digital output, other speakers, etc.......
Operating System
Operating System
Yeah i have one empty space but im not fussed! its the way its designed mabye there was a update or somin that changed it!
Intel Pentium Dual Core E5200 Overclocked @ 2.90
ASUStek
OCZ DDR2 PC2-6400 Vista Performance Gold 4GB Dual Channel
ASUStek ENGTX275 PCI-E x 1
19inch benq
1400x900
400 gb
700 Watt artic power
Artic cooler
4.70 mb/s download, 0.37 mb/s upload
thanks for the answers,
It looks like a programming error in Windows. The programmers did not include the part of the code that resizes the window automatically
what do you think about that?
LENOVO G-530
# 250GB 5400RPM HDD
Well, that or they programmed it to have 4 spaces displayed by default. It's also the same way in Vista as well as in Windows 7.
Operating System
Operating System
thanks Brink,
"they programmed it to have 4 spaces displayed by default."
can you please write down the link to this interesting statement?
LENOVO G-530
# 250GB 5400RPM HDD
That was a statement by me based on observation. Vista and Windows 7 both seem to have space for 4 volume levels by default.
Operating System
Operating System
OK,
you are the MVP and have the experience.
i consider this issue as solved.
thanks again .
LENOVO G-530
# 250GB 5400RPM HDD
No problem Prukeyhi. There just does not seem to be a way to change this.
Operating System
Operating System
