microphone not able to transmit sound..help plz
amitlohan
Dear sir
I am having vista home premium 32 bit. Recently i bought iBall 630MV microphone. I am able to hear everybody but not able to transmit/record. On the other laptop having XP its working fine. Is it a driver problem? if yes Wht should I do, I m trying from last 6 hrs
I hope I'll get help from you
Dear sir
What driver did you use on XP? do you still have it? I cant find a driver for it. You may have to install the XP driver in compatibilty mode. To do that you right click the file goto properties. click on compatibilty tab set f or XP
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
