Hi everybody i'm new here
hope you can help me...
there's no (and there was no) audible sound for taskbar notifications (balloons).
E.g-in windows update (i set it only to inform me, not download).
there is a balloon notification but no sound.
sound options are all enable and working
other sounds appear ok, i Can hear them.
Windows - Balloon.wav" correctly associated with System Notification- and sound test is working.
changing between sound schemes also does not help...
any idea how to enable balloon sound ?
(In XP baloon notif. sound is working but not in my vista...)
*Maybe i'ts vista default behavior?
- LENOVO G-530
- Other Info
- # Intel Pentium Dual-Core T3400 (2.16GHz, 1MB L2 cache, 667MHz FSB) # 15.4-inch glossy 16:10 display (1280x800) # Intel Graphics Media Accelerator 4500MHD # 3GB DDR2 667MHz RAM # 250GB 5400RPM HDD # SuperMulti DVD+/-RW Optical Drive # Broadcom WiFi (802.11b/g), 10/100 Ethernet, Modem # 6-Cell 11.1V 53WHr Battery http://www.notebookreview.com/default.asp?newsID=5022&review=lenovo+g530
