Vista Reducing Volume With No Input
margaritapc
I have a Dell Inspiron 1525 running Vista Home Premium 32 bit.
Three days ago the computer began reducing the volume to zero on the sound mixer. When I raise the volume the slider returns to zero.
Thanks
Thanks
In sound control panel do you have either room correction, or sound equalization checked?
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
No they are not checked. Windows Media Player is also acting the same way. I can increase the volume but it slides right back to zero
Ok lets see what device manager says. can you go start>search>device manager> look for your sound device and see if it is installed and working correctly. If it had a yellow traingle on it or if it not there and there are another "unkonwn devices" you need to re-install the driver.
let us know wht you find
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Mine suddenly gave a loud whistling sound when certain songs are played.
It started when I activated Windows Defender.
I came to this forum to find out how to deactivate the program which I did.
Now my Windows Media Player is playing normally!
    Acer Aspire M5800
    Intel(R) Core (TM)2 Quad CPU Q8400 @ 2.66 GHz
    Intel (R) 4 Series Chipset
    4.00 GB
    ATI Radeon HD 4650
    Realtex High Defination Audio
    Dell E207WFP
    1680 by1050 pixels
    ST3320418AS
    Acer wireless
    Microsoft
    1000 mbps
    IE 8 Windows Media Player
