5.1 sound not playing out of all speakers
ComicBookGuy
Hey.
I have Logitech X-530 speakers, a 5.1 setup. Yesterday I wanted to use my headset to play a game, so I had to change my settings to stereo to get the sound out of both the left and right headphones. When I had finished, I changed it back to 5.1 through the control panel, but now the sound is only playing out of the left and right speakers. All speakers are functional, since when I test it through the control panel the 'bing' sound plays through all one-by-one. The speakers worked fully in 5.1 before I changed the settings.
Windows Vista 32bit SP2.
Thanks.
    Dell Dimension 9200
    2 GB
    NVIDIA 7900
have you tried giving you computer a system restore this should store all your old factory settings if you do not know how to do this just reply back for more help thank you :)
I've enabled speaker fill, but I don't really want this. It tries to channel stereo into 5.1, but it just ends up making the audio quality poor. How can I make it like it used to be - channel stereo the same levels out of all speakers, but channel 5.1 as it should be.
    Dell Dimension 9200
    2 GB
    NVIDIA 7900
CBG
we really need you to fill in your system specs (lower left corner of your posts) so we know what hardware you have. We could also use what aduio card you have?
thanks
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Sorry, I'm not sure what audio card I have. dxdiag says Sound 1 is Speakers (High Definition Audio) and Sound 2 is Digital Output Device (SPDIF)
    Dell Dimension 9200
    2 GB
    NVIDIA 7900
if its a dell dimension 9200 then your soundcard is this:
Type: Sound card - plug-in card
Audio Adaptor: Creative Sound Blaster X-Fi XtremeMusic
Sound Output Mode: 7.1 channel surround
Compliant Standards: Dolby Digital Surround, THX, High Definition Audio
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Only if he added one (either at the time of purchase, or after),
Documentation
Audio
Type
Sigmatel 9227 audio codec
Internal 7.1 channel or PCI option cards
This,
looks like the drivers either aren't installed, or have been corrupted somehow. If it is the Sigmatel onboard have a look around in this forum to find one newer than what Dell has listed on their site; over 2 years old, and there are newer Sigmatel drivers, just not listed for your comouter from Dell.
If it is the Xtreme Gamer same thing, the drivers from Dell are ancient (from mid-2207). About the best driver set going for the X-fi cards (not the Xtreme Audio though) is this,
SB X-Fi Series Support Pack 2.0 (05/15/2009) - Creative Labs
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Thanks, this worked great.
However, I have a different problem now. Whenever I plug in my CREATIVE headphone/mic set it still plays out in 5.1 - by that I mean only the left and right speaker sounds play thru the left and right headphones. I am not hearing anything from the middle or two back speakers. In my case, I cannot hear people in Steam voice chat, but I can hear the game sounds.
Thanks.
    Dell Dimension 9200
    2 GB
    NVIDIA 7900
It set to Game Mode when playing games? You can also set it to headphones from within the Console Launcher/Game Mode options.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Open the Creative Console Launcher (if you installed the daniel_k drivers you should have it) from either the Creative folder in the Start menu or from the Volume Panel icon in the notification area (if it is running). Then you can make all the changes from there (modes, speaker settings, mixer, EQ, etc).
Might be a good idea to grab this (you will have to right click, select Properties and click on Unblock before you can open it),
Creative Worldwide Support > X-Fi XtremeMusic
Click on "Quickstart user Guide" and download the manual (Filesize: 998.85 KB), and see what all your card can do.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
I actually installed the SigmaTel drivers, since I think that is what is meant to be used on my machine.
    Dell Dimension 9200
    2 GB
    NVIDIA 7900
