No sound on BRAND NEW headset....
Sato
Ok...So i just bought the Fatal1ty usb gaming headset HS-1000...And get it home...Install disk and then plug it in and guess what happens? No sound...Period..except for its sound check which says "Channel right...Channel left." Or some static sound check...Other than that. No youtube videos or anything else. PLEASE help!!!
right click on ur speaker in ur task bar, and go to sounds. then in there u need to set ur headset as default.
    Me
    i7 920
    Asus P6T
    12 gigs corsair (TR3X6G1333C9 x 2)
    Dual 285 GTX's
    Sennihesir 350 headset.
    Dual 24" dell
    1920x1200
    WD VelociRaptor 300GB Seagate baracuda 7200.12 1TB
    Thermaltake 1200W ToughPower
    Antec P193
    Air(ATM)
    G9
    Orginal G15
    Cable
Already a step ahead of you...Been there and done that. Yet the sound still refuses to work. On the auto update it says it cant even detect a device...Which confuses me when I can hear the set up stuff...Yet nothing else.
Can you give me a idea what u already have done??? did you go to device manager and see if you can see any problems in there??
    Me
    i7 920
    Asus P6T
    Dual 285 GTX's
    Dual 24" dell
    1920x1200
    Antec P193
    Air(ATM)
    G9
    Orginal G15
    Cable
