Creative Titanium sound card
Techymike
not so newbie
Power User
Just installed a Creative X-FI titanium and worked perfectly in Vista 64 bit. I had to use the PCIE x4 slot as the X1 slot would not fit on the motherboard due to the heat sinks. It really did make a huge difference in the sound quality from the on board sound.
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
Let me know in a couple of days how you are liking it! I need to get a new sound card, and I was looking at that one. What onboard sound did you have tho?? I have the realtek HD audio with builtin fiber for sound!
    Me
    i7 920
    Asus P6T
    12 gigs corsair (TR3X6G1333C9 x 2)
    Dual 285 GTX's
    Sennihesir 350 headset.
    Dual 24" dell
    1920x1200
    WD VelociRaptor 300GB Seagate baracuda 7200.12 1TB
    Thermaltake 1200W ToughPower
    Antec P193
    Air(ATM)
    G9
    Orginal G15
    Cable
On my motherboard there is what is called Azalias Codec that is disabled in bios for an 3rd party audio card. Most MB's set the audio as enabled for an auto set up so you will need to set it for disabled when installing a 4rd party audio card. Every audio option is set up by the Titanium card drivers, the new update supersedes the factory march 2008 drivers. The factory default selected the speakers by option but I manually set the default to fiber out, that is SPDIF out. I honestly did not expect to hear a difference from the realtech audio but I really did.
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
Owe, Best buy had it on sale for under $100.
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
