missing wma codec
oswold
can anybody help? i have lost the abillty to rip cds in wma format with any ripper. the cds i have ripped earlier play ok but i can no longer rip new ones
In Windows Media Player, when you click the arrow on the rip tab and can select settings, is WMA listed? If not, try using the System File Checker.
Open up a command prompt as administrator, by typing cmd in the start menu, then right-clicking and selecting :run as admnistrator. Then type this:
sfc /scannow
You might need the vista dvd. If that doesn't work, try using system restore to try and undo any changes if you installed any new software and/or drivers.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
does it have to be in WMA format?, restart your PC and then give it a go, if not get back to me.
    Core2Quad Q9550 @ 2.83Ghz O.C'd to 3.86Ghz
    XFX Nvidia 790i Ultra SLI
    4x2GB Corsair DDR3@ 1333Mhz
    Asus Nvidia GTX 280
    Creative PCI Express X-Fi Titanium Fatal1ty Pro Series
    Benq 24in 1920x1080, Viewsonic 22in 1680x1050
    1920x1200 + 1680x1050
    Samsungx2 750GB SATA II 32MB SATA Hard Drive RAID 0 array
    Antec 850Watt
    Cooler Master Cosmo S 1100 Extended ATX No PSU Aluminium Blk
    7x 120mm Fans
    Logitech G7, Logitech G9
    Logitech Dinovo Edge, Logitech Dinovo Mini
    24Mbit p/s
