Mic doesn't work unless i unplug, plug back in
bushpilot223
Hello,
My microphone does not work after I reboot/start my computer unless I unplug it for about 5 seconds and plug it back in so RealTek can redetect it. Then it works fine until I shut it off or reboot the computer and then I must do it again.
I have looked on Google and I can't find anything, just other people having the same exact problem without fixes.
I have a BIOSTAR TA790GXB A2+ AM2+/AM2 AMD 790GX Full-Atx mobo from newegg right here: Newegg.com - BIOSTAR TA790GXB A2+ AM2+/AM2 AMD 790GX ATX AMD Motherboard - AMD Motherboards
I have the latest BIOS version as well. I used the BIOS update utility that came on the motherboard CD. I also have the latest RealTek drivers and have tried reinstalling several times. And like I said before, this was happening before I reformatted too, but strangely about 2 weeks before I formatted it just stopped happening and worked fine...... so strange.
Help please!
Thanks!
Make sure that your front audio ports are plugged into the motherboard, and are not loose.
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Labtec Media Desktop Y-SAD65
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
