I have a set of files saved on a hard drive which were copied from a video DVD. Is there a way to burn a DVD out of these files so that the DVD can be played by an ordinary DVD player?
Thank you very much for your detailed suggestion. It worked.![]()
Yup, if you have vob/ifo/bup files, that is basically dvd data. If you do anything to "convert" it, you'll lose quality, burn as data in a folder called Video_TS and you are good to go!
