Disable Speakers
luddy
I was trying o get my headphones to work and I mistakenly "disabled" my speakers in "control panel>sound". It not only disabled the speaker option but it made it disappear completely. How can I get it back? I now have no sound other than headphones.
    Pent Quad 3.0 ghz
    Asus Striker II Extreme
    Kingston 4 gig
    GTX 285
    Sound Max HD
    WD Velociraptor 300
Thanks all!!!! I figured it out myself...........Open the "sounds" window in the Control Panel>Right click in the box, a drop down menu appears>click on "show disabled devices".
    Pent Quad 3.0 ghz
    Kingston 4 gig
    GTX 285
    Sound Max HD
    WD Velociraptor 300
here's another one for you, I can't get the narrator to shut up! I started voice recognition,and now I can't use the keyboard after I log on to Vista--any ideas? from anyone?
  • Other Info
    post:help pi can't get the narrator to shut up or turn off vopice input and resume keyboard input after I log oj to vista ultimate.1
