nativecode
i have a strange problem on Vista x64. Previously, with Vista SP1 x32 I used the advanced settings to switch on the "Make external and internal output devices playback two different audio streams simultaneously" option. That way I could keep two different settings for speakers and headphones. I had the Speakers on mute and the headphones on. That way the internal speakers would be mute but when I plug-in the headphones the audio would automatically switch on "unmute".
However since I installed x64 I find that it shows two separate tabs for speakers and headphones as normal but if the speakers are set to mute audio would be muted for everything including the headphones. I checked everything and eventhough the headphones are set to "unmute" the headphones would only work if I went to the speakers tab and "unmuted" the speakers. Doing this means that when I unplug in the headphones the internal speakers are on.
I tried updating to version 6.0.1.5888 to no avail. Can anybody help. Sorry for the long explanation but i wanted to give you as much info as possible.
Regards,
Native
Regards,
Native
