USB Sound Card Trouble
FlameKilla
For about nearly a year now I haven't had sound on my computer because my onboard sound card went out. So today I went and got a USB sound card hoping that maybe it will get my sound working. I put it in and installed all of the drivers and it says that it is working properly, but I still can't hear any sound. There is a red X over the stereo symbol in the bottom right corner and when i try to go to the volume mixer it says no audio device is installed. How can fix this?
did you look in device manager for any problems with sound hardware?
did you uninstall and/or disable the old sound card?
check the manufacturer's website for the latest driver?
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
