I need speakers for my laptop any suggestions?
kwarped
I am looking around for speakers for my laptop and not sure of what is really a good pair for a reasonable price. I am running vista x64 ... any help would be grateful..
just depends on what you want and what you are going to use them for.
music or gaming i would get ones with a sub.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
well to be quite honest, i am not that familiar with speakers at all.. I have some old ones here that was hooked up to my desktop and I wish that I could use them but they are the plug in type and I'm not sure if they have a usb adapter out that I would be able to still use them.... I basically just want a simple set up being that i don't know anything about speakers...ty for replying!
go to walmart or target if you have them in your area and just get some that will work.
don't go to cheap or to expensive go for the ones right in the middle price range.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Would you like a simple left and right speaker? I would recommend go for 2.1 speakers with a sub woofer. Im using it in my laptop and i m quite happy with it.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
thank you for your replies, i think that I might just do that and get some speakers from walmart... I never thought of looking in walmart....
you can get them there for like 50 bucks for 2 speakers and a sub and it sounds decent.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
