Speakers for XPS 435MT
ColColt
I have a Dell XPS 435MT and am trying to find some speakers for it. I haven't had any luck on Dell's website other than some cheap $20 jobbies. I don't need 4-7 speakers with sub woofer, etc as I have all that with my older XP system but, I'd like to find some decent ones for the newer system with Vista Home Premium. Can someone steer me in the right direction for speakers for this system? They don't necessarily have to be Dell.
    Dell XPS 435MT
    2.67 gigahertz Intel Core i7 920
    Dell Inc. 0R849J A00
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ 640G
    10Mbps
Apparently this is not a very popular forum. I've noticed quite a few post have been made days ago here and still no answers...oh well.
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    10Mbps
sorry you feel like that, some of our members have a life outside of the internet and its just not possible to read your post until we are online, in reply to your first post though, the great thing about PC's, anything will work with it, it doesnt have to be branded, im using an amplifier connected to 2 satellite speakers and a subwoofer, and my friend across from me uses his home cinema system for PC audio. you can choose what you like to connect as long as it can connect via the audio jacks at the back.
heres a midrange set to look at by altec lansing http://www.newegg.com/Product/Product.aspx?Item=N82E16836113016
Have fun.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
heres a midrange set to look at by altec lansing Newegg.com - ALTEC LANSING VS2421 28 Watts 2.1 Gaming Speaker System - Speakers
Have fun.
I realize that but, it seemed rather odd to have 20 post and half of them had zero replies after days of being there. At any rate, that particular system isn't available anymore per Altec's website. I had hoped of usinig my older (7 years) system from my XP system from Dell with this new system but the connectors are different. Most of the time you're never shown the connectors and so you can't be sure what you're getting is correct...thanks anyway.
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    10Mbps
Have fun.
the standard jacks are the same on my system now as they were when i got my first system about 10 years ago, any speakers work as long as the jacks are used, which they are, its an intel 7.1 HD audio soundcard built into the Dell XPS 435MT and they use standard audio jacks like all other systems. Pick which speakers you want, your choice.
    16Mb Sky bb
I had hoped maybe I could use the speakers from my older XP Dell Dimension machine but they don't have the same connectors required to fit the XPS. There are not jacks but rather look like a S-video connectors. That's why I was in the market for new ones that would work. I'll shop around.
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    10Mbps
