Microphone not detected after installation of SP2
Lebon14
Hi guys.
I'm on my friend's computer at the moment. It has a strange problem. The microphone, after installing the 64-bit SP2, is not detected anymore by Vista/Creative SoundBlaster X-Fi Extreme (PCIe 1x).
The microphone in question... is a simple microphone. Not USB.
His config is :
4GB of RAM (1033MHz DDR2)
320GB of Hard drive
Ati Radeon 4850 512MB
Creative SoundBlaster X-Fi Extreme Sound Card
Realtek HD On-board Sound (Desactivated)
Windows Vista Home Premium (FR) x64
The drivers are up-to-date. I even desinstalled them and reinstalled them. Of course, I tried to connect/deconnect.
Are there any other things we could try? (Without spending a penny please).
My friend wants to try everything possible before getting on the on-board audio chip.
Thanks for helping.
EDIT
Something was wrong in the creative software. But we got it working now.
Thanks anyway.
    Core 2 Duo E6600 2.4 Ghz
    Gigabyte P35-DS3R
    Kingston 4x512MB 667MHz DDR2
    nVidia GeForce 8500GT 512MB
    1x Maxtor 200GB 1x External LaCie 250GB (USB 2.0) 1x Western Digital 500GB All are 7200RPM
I hope someone helps because I have the same problem and I am running almost iden tical hardware. I am using Vista Ultimate (64 bit).
I am using Soundblaster X-Fi Platinum Series.
Windows will nor recognize the microphone.
^ It has to do with the Creative software. I don't remember exactly which one or where but in one place you can change what jack does what. In that choice, I think you have "Microphone jack". The problem lies in the Creative software. It's not Windows ;)
Keep searching.
    Gigabyte P35-DS3R
