You should upgrade or use an
alternative browser .
Solved No "Ding" Sound when Adjusting Volume In Tray
When adjusting my volume by clicking the speaker in the tray it used to give me a sample ding after I moved the slider and let go of it. Now it's silent.
It had me thinking I had a no audio problem until I played a music file.
I went into sounds and looked for a reference to the conmand to see if there was no sound assigned but cannot figure it out.
Home Build
Intel Q6600 G0
Gigabyte GA-EP45-UD3P
Corsair 8GB
POWERCOLOR AX3650 512M DDR2
On board
Samsung 215TW
2X WD 750GB RE3 RAID-1
610W CORSAIR Modular
Cheapo Rosewell
Rosewell Fans and CPU Cooler
Logitech MX Revolution
Logitech Access Keyboard 600
re: No "Ding" Sound when Adjusting Volume In Tray
Hello Rock,
In
Sounds , double check to see if the
Default Beep event has the
Windows Ding.wav file set for it.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Thats it,
thanks
Home Build
Intel Q6600 G0
Corsair 8GB
On board
Samsung 215TW
Cheapo Rosewell
You're welcome Rock.
Operating System
Operating System
