Hi all,
I keep having to reboot to get my sound back.
This has been going on since I got the laptop 9/2008
When I called support in the beginning, of course the ans was uninstall/reinstall sound drivers then the tyipical reinstall.
Maybe you all have an answer?
Carmine
ps:
this is a gateway laptop m-6881
System Manufacturer/Model Number gateway/m6881---gateway/s500s
OS VISTA home prem 32bit --- XP Pro SP3 32bit
CPU dual core 2.2ghz --- p4 2.0
Motherboard ?
Memory 3GB --- 512mb
Graphics Card ?
Sound Card ?
Monitor(s) Displays ?
Screen Resolution ?
Update your System Spec
Keyboard ?
Mouse logitech
PSU ?
Case ?
Cooling ?
Hard Drives 250GB WD --- 200GB segate
Internet Speed fios 10MB --Bull$#iT
Carmine
ps:
Motherboard ?
Graphics Card ?
Sound Card ?
Screen Resolution ?
Keyboard ?
Mouse logitech
PSU ?
Case ?
Cooling ?
- gateway/m6881
- centrino core 2 duo 2.2ghz T7500
- 3GB
- 500GB WD
- logitech
- fios 35MB not!!!!
