IRQ Wireless USB Conflict with Sound Card
Fixxor
Hey All,
I wrote a couple of days ago about stuttering sound, and how it would kill my FPS in Bioshock or any other games. I looked in my system info and saw this:
<img src="http://img17.imageshack.us/img17/883/irqproblem2.png">
Are these two conflicting? How can i solve this problem if they are? Can someone walk me through changing an IRQ?
    AMD Phenom II Quad Core Deneb
    Asus M4A79 Deluxe
    8 Gig Corsair PC 5600 Ram (not up to speed with new mobo i know...)
    Nvidia Geforce 8800 GT
    Asus Xonar DX
    Sceptre 20" LCD
    dont know
    Hitachi 500Gig
    Antec 500W
    NZXT
    Zalman
    Razer Diamondback
    Razer Lycosa
    Cable
    Creative Headset HS-1000 which sparked my audio problems... Drivers since uninstalled.
Shouldn't make any difference. One thing I can think of, you don't have any of the audio settings in your games set to hardware do you? If so set it to software and see if that fixes it.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
I use Linksys/Cisco WUSB600N ... (USB wireless -N adapter) and have no issues.
I would try Uninstalling the Audio Drivers and reinstalling.
Also check your Game Settings.
Goto Device Manager take a look for problems too.
You maybe able to Change Wireless Frequency from 2.4GHz to 5GHz via modem/router since it could be causing interference.
Keep Cordless or Cellular Phones away from the PC as could possible cause interference.
Make sure you have the latest game patches and/or drivers for both Video and Audio cards. If integrated with Motherboard ..check with Mobo manufacturer and get the correct one for your Operating System , such as Vista, WinXP and proper
Bit as 64 or 32.
The reason I believe my problem to be IRQ related is because my audio stuttering goes beyond gaming and into simple video playback (youtube). I get stuttering even on a low quality video.
I will uninstall my audio drivers, and re-install them when i get out of work. I will let you all know if that has solved my problem.
    Asus M4A79 Deluxe
    Asus Xonar DX
    Sceptre 20" LCD
    dont know
    Hitachi 500Gig
    Antec 500W
    NZXT
    Zalman
    Razer Diamondback
    Razer Lycosa
    Cable
PROBLEM SOLVED!! THANK YOU FOX MAN! It was all a conflict between my WIRELESS N USB Adapter, and my on board NIC ETHERNET CARD!
See here in my screenshot!
    Asus M4A79 Deluxe
    Asus Xonar DX
    Sceptre 20" LCD
    dont know
    Hitachi 500Gig
    Antec 500W
    NZXT
    Zalman
    Razer Diamondback
    Razer Lycosa
    Cable
