No Sound GTA lags
DevourOfDarknes
I just turned on my computer and noticed two things.
One: The speakers are working but there is no sound.
Two: GTA SA laggs.
When I click the audio icon on the taskbar and adjust the scroller, the green bar that jumps up does not jump and when I try to configure the speakers or play a windows sound from the sound option in control panel, it says "error cannot play sound." It still says working in the main sound window. I have not done anything apart from installing some windows updates.
Also, if this matters, GTA San Andreas laggs terribly but it never used to at all. The amount of RAM and CPU usage is just normal. Help would be appreciated.
Dell Inspiron 518 2GB RAM 32bit Intel Dual Core 2.53GHz Direct X 10 Intel Express Chipset Family 286MB
    Dell Inspiron 518
    2GB
    ATI Radeon HD 4670 512MB
    Realtek HD
    Dell 20 inch
    250GB, 500GB Seagate
    Dell wired
    Dell wired
    5000 Download 1000 Upload
