speaker 5.1 not working
kinalas
using vista 32 bit
speaker is set as 5.1
testing the speaker results are all good. all speakers are working
but if play audio/video only 2 satellite speaker and the subwoofer are working
help
Do you have a game that uses 5.1 sound? Most is 2 speaker stereo.
    16GB DDR667
    SAS RAID
Kinalas, check your driver, I was having the same problem, it turned out to be the driver I was using was a dud.
Also, once you uninstall and install new drivers, make sure to unplug and replug the cables back so the software manager can pick up your speaker system.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
    Me, myself and I
    Intel Core 2 Duo E 8500
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    Asus GeForce 9800GTX+
    SoundBlaster X-Fi X-treme gamer
    Samsung Syncmaster 226BW
    1680 x 1050
    1x 250gb SATA 4x 1TB SATA in RAID5
    CoolerMaster 650Watt
    CoolerMaster 690
    4x 140mm, 3x 120mm, 1x 80mm casefans
    Logitech G5
    Razer Lycosa
    ADSL 12mbit/s
    My other OS is a Linux =)
