Vista x64 5.1 not working
and1dude
My 5.1's rear speaker sound comes out from front speakers.
I was using xp pro before, works perfect.
recently i installed vista x64.
Driver for Creative x-fi Xtreme is installed, when i click rear speakers,
sound comes out from front speakers,
front speakers and bass is fine.
Spec:
x-530 logitech 5.1
Vista Ultimate x64
This is what someone else tried and apparently worked for them.
""I dual boot with Windows XP and on the XP side the X-Fi drivers are pretty much workingly perfectly at this point. However on my Vista 64 side I quickly identify three issues that always seem to come up.
  • Speaker configuration not properly detected. Even though Vista is setup for 5.1 sound, the drivers default to 2.0.
  • Even if the speakers are changed to 5.1 in the Creative control panels, I still only get 2.0 sound.
  • Creative settings reset everytime the computer reboots.
  • Can not hear mic.
Speaker Configuration:
It sounds like the CTXFIREG.exe process is suppose to be the one that detects that I have a 5.1 speaker configuration in the Windows audio control panel and synchronize this setting with the Creative control panels, but it doesn’t. To fix this I just launch the Creative Console Launcher. Go into each of the three modes, Game, Entertainment, and Audio Creation, and set the speakers to 5.1 manually. But don’t do that just yet until you see the next paragraph.
2.0 Sound from 5.1 Speakers:
Even after I manually set my speakers to 5.1 in the Creative control panel, and I successfully hear test tones from all 5 speakers, I will still only hear 2.0 sound from games and movies. I found the fix for this is to launch the Creative Console Launcher, go to Game Mode and press the default button. This resets the speakers back to 2.0, but now when I select 5.1, I’ll actually hear 5.1 from my games and movies. Repeat this for the Entertainment Mode too. Make sure Audio Creation is still set to 5.1 mode, but it has no Default reset button for this mode (I don’t really use this mode anyway).
Creative Settings Reset:
Unfortunately after you’ve fixed your speaker out configuration and you got your movies and games sounding right, you might find that after rebooting things go back to 2.0 sound again. Sometimes it may not even happen after the first reboot, but later. Apparently the cause is that CTXIREG.exe process again. That process that supposedly tries to synchronize settings between the Windows and Creative control panels. Something doesn’t go right and the settings get reset by this. Disabling this process with MSCONFIG (or removing it from HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Run) seems to fix the problem."
VN Boards - Creative X-Fi Xtreme with Windows Vista 64 SP1 Guide
    Home Built
    Q6600 @ 2.66ghz
    Asus Maximus Formula
    8GB Patriot PC2 6400
    Geforce 8800GT 512mb
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Western Digital 640GB 32mb cache
    Cooler Master 750W
    Cooler Master ATC 201C-SX1
    Stock Intel CPU fan 4 80X80mm case fans 1 120mm case fan
    Logitech MX Revolution
    Logitech G15 gaming keyboard
    RR cable 10Mbps with 16Mbps boost
    Sennheiser PC350 Headset
Thanks alot Nunyabiz.
Unfortunately my Creative Console Launcher doesn't have those settings in it =[
But I clicked Creative Diagnostics, and everything seems to be fine now =]
Thanks once again people .
