Solved mic only picked up once jack removed/plugged back in
pimp
Hi Guys,
Ive got a problem where the mic is only picked up once it is unplugged and plugged back in again. Ive updated the drivers and put a splitter in the mic jack to try and stop the socket from wearing down. The problem is I have to remove the splitter and plug that back in for it to pick it up now. Its an
Asus P5N-E SLI 650i Socket 775 PCI-E Onboard Audio ATX Motherboard running onboard sound with realtek drivers.
Any help would be great :)
Tony
    Intel Core 2 Quad Q6600 Energy Efficient 95W edition Socket
    2 X OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM XTC with LIFETIME WARRANTY
    ASUS NVIDIA GeForce 8800GTX 768MB GDDR3 DVI HDCP HDTV out PC
    Western Digital WD5000AAKS 500GB SATA II 7200RPM 16MB Cache - OEM
    Antec 650W Neopower Modular PSU - Blue LED 12CM Fan
    Antec 900 Nine Hundred - Gaming Case with 200mm Top Fan - No
    Arctic Cooling AC-FRZ-7P Freezer 7 Pro Socket 775 Processor
    5 button logitec
    cheapo argos value one
    3MB
Looks like I have found the problem on this one. There were multiple input devices and the mic was not set as the default. This was why I was having to remove the jack and put it back in again. Once mic was set as default it works fine every time without having to remove the jack
    5 button logitec
    3MB
