Sound device not detected on vista 64 home premium
nicolas10
Hello,
I've just setup a new computer with vista but after installing, vista didn't detect any sound device.
I have an Asus Rampage II extreme board with the supreme fx audio module installed. HD sound is also activated in the BIOS.
What should I do?
Did you touch anything on your Bios prior to the Vista install or even afterwards? Perhaps you missed something and you disabled it?
What do you have on under your Device Manager/Audio options?
Have you installed the CD that came with your Motherboard yet? if not, do so or go over the Asus site and download the latest software for your mobo and install it.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
I checked the bios and the onboard sound is enabled...
I have installed vista with the original CD... and I have installed all the drivers that came with the ASUS CD. Also, I downloaded the vista 64 drivers on the ASUS website... but when I try to install it I get an error message saying no device has been found.
Nic
Nic
Hi Nic,
Welcome to the forum.
What Graphic card are you using??
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
Thanks for the welcome;
here's the system:
Asus rampage II extreme
core i7 i940
gainward GTX295
2x 150 mb velociraptors in raid 0
1 stick of OCZ memory (2gb)
Nic
here's the system:
core i7 i940
gainward GTX295
Nic
Hi Nic,
Sorry about the delay, I am learning on this as I go :confused: Your problems are probably being caused by the Video Cards HDMI output.
Apparently you can choose between your mobos sound and nVidia HD Audio by going to Control Panel - Sound
What you can also do is to have a look or even ask here;
NVIDIA Forums
I hope this helps Pooch
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Thanks for the input. I'll investigate that way. But shouldn't vista at least detect the onboard sound?
And does that mean I could use my vid card as a soundcard? :shock:
When I go to the control panel it doesn't find any audio device whatsoever.
Nic
I think yes, It could be possible that your mobo sound is dead. You could try uninstalling the Video drivers then try to reinstall the sound drivers
As I understand it yes, connecting HDMI to a TV
What do you have in Device manager?
The mobo is new you also have the RMA option at least get the dealer to check it
Pooch
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
I have no sound device at all in the device manager.
RMA means I won't have my MOBO for a month at least.
WTF I have to RMA the memory AND the mobo. Talk about bad luck!
I have just noticed something, Your sound is not onboard like I was thinking but plugged in to the mobo. Have you tried taking it out and re-seating it??
If you have to RMA as I suggested. Then it would probably be just the sound card not the Motherboard
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Yeah that's the first thing that I've tried when I noticed sound wasn't there. I'll call the place I purchased it from and I hope
they won't ask me to send the whole box back.
I've installed my ole Audigy 2 ZS wich is working perfectly...
Thanks for the help I think it's indeed RMA time
Nic
Nic
I have got to ask this, Have you installed both the drivers??
By the way this is a really nice board :D
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Whoops forgot the piccies :o
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
I have tried to install both, and both will give me an error message because vista won't find a device. I tried that both with the drivers on the CD (browsing manually as the asus setup won't put them on the list), and with the latest drivers (both) downloaded from the asus website...
Hi
Have you installed the card in the black PCI-e slot, as it won't work in any of the other slots.
Regards
UkMedia
    Self Build
    Intel Quad Core QX6700 4 X 2.66M
    ASUS Striker II Extreme
    4 GB DDR3 1600
    Nvidia 8800GTX 768MB PCI-E
    SoundMax
    2 Flat screen 21" LG displays
    5 internal Hard Drives: 2 x WD 500GB (CAVIAR BLACK 500GB 32MB 7200 SATA) 3 x WD 1TB (CAVIAR BLACK 1TB 32MB 7200 SATA) as Raid 5 array
    Tagan TG 1100W TURBOJET QUAD SLI
    Thermaltake EUREKA Case - Black
    ASUS V60 Quiet with additional fans for H/drives
    Logitech G7
    Logitech G15 Gaming
    0.5 Mb - (Benefits of rural location!)
    Teaming 2 GB network connection to Wired 1GB switch. Connected to 22TB (Raid 5) of network storage on a wired 1GB lan. (Mixture of internal hard drives, 1TB, 2TB & 4TB Terastations)
