Need Suggestions For Sound Card Upgrade (for cassette & vinyl recording)
Wayne Wood
Need Suggestions For Sound Card Upgrade For Windows Vista Home Premium (to be able to record from cassette player)
I want to record my vinyl and cassette music library onto my computer. My version of Windows Vista (Home Premium) does not facilitate music recording (other than ripping cd music using the built-in cd player).
I have tried several cheap external usb sound cards but don’t get good sound reproduction using them. I have checked the specs on internal sound cards and they seem much better than usb models.
I want to try an Asus Xonar D2 sound card. Just about all the on-line reviews and forums for this sound card talk about its good sounding audio playback and its gaming capabilities; hardly anything about recording music from analog sources. Can anyone tell me:
1. Will Asus Xonar D2 work with Windows Vista Home Premium for my purposes?
2. Is this sound card any good for recording music?
3. Are there better alternatives/solutions for recording music on Windows Vista than this sound card?
Thanks for any help!
I have just gotten this sound card and I am extremely impressed with it.
HT Omega - Claro halo XT
So far the drivers & hardware work flawlessly with Vista 64.
I can not imagine why this card would not work for what you are looking to do.
You can also go to link provided and ask their costumer support exactly what you did here and they will answer you within 24 hours.
Also if you listen to music with high quality high impedance headphones then this card is THE best on the market for that.
    Home Built
    Q6600 @ 2.66ghz
    Asus Maximus Formula
    8GB Patriot PC2 6400
    Geforce 8800GT 512mb
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Western Digital 640GB 32mb cache
    Cooler Master 750W
    Cooler Master ATC 201C-SX1
    Stock Intel CPU fan 4 80X80mm case fans 1 120mm case fan
    Logitech MX Revolution
    Logitech G15 gaming keyboard
    RR cable 10Mbps with 16Mbps boost
    Sennheiser PC350 Headset
