Vista 32bit and 5.1 sound problem !
Ollii
Hello everyone! Ive read 10000 forums where guys have been having same problem as I, but I saw none working solutions. : (
So Ive Vista 32bit and Asus P5Q3 motherboard with integrated Realtek soundcard and logitech 5.1 speakers (which worked fine with xp).
What I would like to have is: Have 5.1 sounds out of my mp3's and others music like I did before. Some pll told me that its "simulated" and u cant have real 5.1 with mp3's but Im fine with that... But this feels stupid, having 5+1 speakers from only 2+1 work while listening music. : ((
Thanks alot and Im looking forward to see helping replys for me and many others with this same prob ! : )
Regards, Olli
Do you have the latest audio drivers for the board?
ASUSTeK Computer Inc.-Support-
Maybe update all the drivers for the board if you can.
Even if you have the latest audio drivers it might be a good idea to delete all those audio drivers and do a fresh install of them.
    Home Built
    Q6600 @ 2.66ghz
    Asus Maximus Formula
    8GB Patriot PC2 6400
    Geforce 8800GT 512mb
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Western Digital 640GB 32mb cache
    Cooler Master 750W
    Cooler Master ATC 201C-SX1
    Stock Intel CPU fan 4 80X80mm case fans 1 120mm case fan
    Logitech MX Revolution
    Logitech G15 gaming keyboard
    RR cable 10Mbps with 16Mbps boost
    Sennheiser PC350 Headset
Regards, Olli
Hi Olli,
Welcome to the forum.
Right click on the speaker symbol in the Notification area, select playback devices, select the speaker symbol and then properties you are looking for Speaker Fill and all you have to do is put a tick in the box to get all speakers working with your music
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
Thank you guys very much, especially to Pooch whos tip of using "Speaker Fil" helped:)
Ill put the word out how to fix this "vista 5.1 problem" !
So thanks again and have a nice day ! : )
