speakers/ Vista compatible?
I have just helped a friend to install Vista (64 bit) on a new computer . She previously had windows XP Home. Everything is working fine except for the sound which, even though I have put it to maximum is practically inaudible. Is it possible that she needs new speakers? the ones she has look very elderly! I have checked that they are plugged in ok and enabled.
    Intel Pentium Dual core 2.2GHz
    RAM 4 GB
    250 GB C: drive Maxtor one touch 111 external HD 250GB
    Logitech Wireless
    Logitech Wireless
    Broadband (don't know speed!)
The physical speakers has nothing to do with the upgrade to Vista just as switching gas has nothing to do with tires.
What might be happening is that the audio drivers need to be updated. You'll have to find the 64-bit audio drivers for her soundcard.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
I agree, sounds more like a sound card issue which is the exact problem I just had this week.
I ended up buying a new sound card that works with Vista 64.
New drivers did not do anything for the problem that I was experiencing and from what I understand the driver problems are on purpose from Creative.
So I opted to stop buying their products on purpose.
Newegg.com - HT OMEGA Claro Halo 24-bit 192KHz PCI Interface Sound Card w/ a built-in HI-FI Headphone Amplifier - Sound Cards
Should get it Monday.
    Home Built
    Q6600 @ 2.66ghz
    Asus Maximus Formula
    8GB Patriot PC2 6400
    Geforce 8800GT 512mb
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Western Digital 640GB 32mb cache
    Cooler Master 750W
    Cooler Master ATC 201C-SX1
    Stock Intel CPU fan 4 80X80mm case fans 1 120mm case fan
    Logitech G15 gaming keyboard
    RR cable 10Mbps with 16Mbps boost
    Sennheiser PC350 Headset
That card looks pretty good. How is it? It looks better then my X-Fi card.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
I will let you know on Monday or Tuesday.
I did research it quite a bit before ordering it and everything I read about it put this card substantially better than any Creative card out right now.
And its about the same price.
I haven't seen anyone running Vista 64/32 that says they have any problems with it.
Spec wise it is considerably better.
But I shall see next week.
    Home Built
    Q6600 @ 2.66ghz
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Cooler Master 750W
