my x-fi graphic equalizer settings have no effect on the sound output?
greeneggsandham
Power User
I have a new x-fi titanium. I'm using the optical out to my amp for stereo sound mix. None of the x-fi effects do anything to alter the sound in anyway? At 1st no sound except windows test sounds would even output through the optical out, then all of a sudden it worked for some reason? but none of the bass boost settings are having any effect and the output is low? Anybody have any experience with these sound cards? It's OEM and the instructions on the disc have broken links to retrieve the data online?
    Self Build
    Intel Pentium D 925
    Asus P5Q-EM
    Corsair PC2-8500
    Onboard Intel GMA X4500HD
    On board crap!
    DGM 15" inch generic?
    1280x 1024
    380W Antec Earth Watts
    Antec NSK 2480
    Scythe Mini ninja
    generic
    generic
    Depends what time of the month it is? I have a uk isp.
Hi
Have you selected SPDIF when using your optical out? If so, then all the x-fi features are turned off.
Regards
UKMedia
    Self Build
    Intel Quad Core QX6700 4 X 2.66M
    ASUS Striker II Extreme
    4 GB DDR3 1600
    Nvidia 8800GTX 768MB PCI-E
    SoundMax
    2 Flat screen 21" LG displays
    5 internal Hard Drives: 2 x WD 500GB (CAVIAR BLACK 500GB 32MB 7200 SATA) 3 x WD 1TB (CAVIAR BLACK 1TB 32MB 7200 SATA) as Raid 5 array
    Tagan TG 1100W TURBOJET QUAD SLI
    Thermaltake EUREKA Case - Black
    ASUS V60 Quiet with additional fans for H/drives
    Logitech G7
    Logitech G15 Gaming
    0.5 Mb - (Benefits of rural location!)
    Teaming 2 GB network connection to Wired 1GB switch. Connected to 22TB (Raid 5) of network storage on a wired 1GB lan. (Mixture of internal hard drives, 1TB, 2TB & 4TB Terastations)
No I never selected the SPDIF option, when I did try that it just gave off a mad pulse kinda sound in my speakers. Anyway I had to send the card back as it was stopping my pc from booting up after installing the drivers. Those vista creative drivers are abit dodgy & bloaty. I also tried daniel k's drivers, much better but still had the boot problems. Think i'll get an asus Xonar instead, thank you for your response.
    Self Build
    Intel Pentium D 925
    Asus P5Q-EM
    Corsair PC2-8500
    On board crap!
    1280x 1024
    Antec NSK 2480
    Scythe Mini ninja
    generic
    generic
