No Sound... Tried all week and still nothing.
precisionrides
Hi, I'm new to the forum but I thought I'd get my problem out here to see if someone can help me. It used to work for me before I reformated my computer.
MB= Intel G965 With LPT Port
CPU= Intel Core 2 Quad Q6600
using integrated audio
only pci slot used is Video Card (but in a PCIe slot)
Gateway gt5636e
(with ATI Radeon HD 3650, 2 extra HD's)
My problem is that there is no sound. Updated Drivers are installed and working. I can't play a test tone even. However, Driver Software Installation automatically pops up and tries to find a driver for PCI Simple Communications Controller but always fails when I hit automatic. It's almost like vista thinks their is a sound card in the pci slot. I'm running Windows Vista 64-bit. I've tried disabling Integrated Audio in bios and then reinstalling Drivers then enabling the sound again but to no avail. My next option is to wipe the OS, which I don't want to do. Please help.
Is PCI card comparable to Wds 64 bit vesion...?
It should recognizes and installs the driver automatically or after reboot.....Did you Reboot.....?
    S-Vaio FZ
    Intel Core2duo T7100-1.8GHz
    DDR2-2GB-PC2.5300-Sp.667MHz
    Mobile Intel Graphics Media Accelerator X3100-358MBvideo ram
    200GB/7200Rpm/Serial ATA
That's not going to work. The intergrated soundcard needs to be enabled before installing the drivers! If it's disabled, like you said, Vista will think there's no soundcard. Make sure the card is enabled, then install the drivers.
Also what drivers are you attempting to install? Do you have the 64-bit version?
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
