I lost sound to my pc a while back. Finally had time to sort it out. It was showing realteck speakers not plugged in - they are within the pc, so I tried unplugging things and rebooting to no effect. I then tried disabling and restarting, only problem is I can't work out how to enable them. The files are there, but when I go into control panel sound and manage audio devices it says there aren't any. Even right clicking to show disabled devices doesn't help. Ideas anyone?
- Advent
- intel(R) Core (TM) 2 Duo CPU E4500@2020GHz 539MHZ
