I have been struggling with getting my external speakers to work on my laptop for a few months now. My laptop (Acer) runs on Vista and I plug my speaker into the SPDIF jack on the front of my computer. When I plug the speakers in a bubble pops up saying "A Jack has been plugged in." but there is no sounds. There are no little red x's on my little speaker icons and it seems that the computer thinks that the speakers are working just fine. If I hook my speakers up to my iPod they work just fine so I don’t understand why the won’t work on my laptop. I have very little knowledge about computers and would love some help on how to fix this problem.
Creative Blaster X-FI Titanium Optical to Yamaha Receiver
Panasonic 50 inch Plasma via HDMI and used as just a Monitor
1920x1080
Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
Cooler Master 1000
Antec 900 extra fans
Cooler Master Hyper-N520
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
My laptop is a Acer Aspire 5570. I bought it mid 2007 if memory serves me right. The speakers are little SONY ones. I don't remember there name but on the side it says Active Speaker System SRS-M30. I bought them around July of 2008.
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
There was no CD or need to install these speakers so would there still be a need to look into trying to update the speakers. Sorry I am not good with computer so I don't really understand what a driver is and how it would help my speakers to work.
I am not sure about that. I was just seeing of the option for a Vista support driver. It is hard for me to offer help as I am not sure what level of information you know about how and what to set up your system for working of audio set ups. It appears that you have some option in the audio not established for external speaker hook up. That could be a bios or configuration setting for the audio settings. When you reboot with the speakers hooked up, the system does or does not recognize that you have external speakers hooked up?
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
When I restart my computer with my speakers all hooked up there is still no sound.
If I go to the sound setting and under the playback tab there is a green check mark beside speaker and it says "working" but still no sound. Also the Realtek Digital Output says "working", too. I don't know if either of these refer to external speakers but maybe it's helpful.
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
Lets start here. At the bottom right hand of your computer screen, there is a speaker display (icon). Right click on that and select playback devices. If there is no speaker display then go to control panel and select sound then open that. There will be a window that opens and gives you a selection of what device is being used by a green check mark, the others will be a red arrow. What is checked green and what is red?
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
In the playback tab there is a green check mark beside speaker and it says "working", there is also the Realtek Digital Output icon but there are no check marks and it too says "working".
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
Well from what I understand the green check mark just means what is set as your default device. So if i put the green check mark onto the Realtek Digital Output icon there will be no check mark on the speaker icon. But even with the check mark on the Realtek Digital Output icon there is still no sound.
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
Have you tried changing the default settings? in the screen you showed me? I see the speakers are a red check mark. With the current configuration you are letting realtek be the output source to an external speaker. Is the digital or analog output selected?
What is displayed in the "Device Advanced Settings" ?
1920x1080
Cooler Master 1000
MX 5000 Logitech
MX 5000 Logitech
Cable 12MBPS
