Internal optical drive nor external NEC dvd burner functioning with new notebook
gene gayle
I have an ASUS G50VT notebook that is 3 weeks old and I am running Vista Home Premium 64bit for my OS. My ODD was working jsut fine, now I can not read anything. In Explorer I can see the drive, but it does not read anything. I have unistalled the drive several times and rebooted, but did not work, I have also tried to edit the registry, but lower filters and upper filters are not listed to delete. After reading some other forums and also talking to Geek Squad they all said that my drive is bad and needs to be replaced.
With that thought in mind I have an older external NEC dvd burner that I hooked up to my new computer and the nc does the same thing with this drive, but when I hook it up to my old notebook (dell inspiron 1150 using XP) it works fine. This leads me to believe that possibly my problem is with Vista, but I do not know what to do. Can anyone help me please.
Thank You
Gene
    Asus G50VT
    Intel Centrino 2
    Nvidia GeForce 9800m GS 512 MB
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Thanks Stormy for your reply, I did check in Device Manager and under the General Tab. There are no error messages and it says that the device is working properly
    Asus G50VT
    Intel Centrino 2
