i'm in need of a good idea concerning my bluetooth headset.
using skype i bought a plantronics voyager 520 to use it also for my mobile. vista ultimate 64 nicely installed the device, broadcom is also on the system , rights fo connection were given - well the system worked well until - i have no clue. I did not chage anything but wenn I start skype and mybt headset it is recognized, the software is installeb, sound is on, mcrophone and earplug is checked in the bt device manager. wenn i start the skype test i hear a beep and then background noise but no voice or sound. sound and mic monitors are moving - it seems as if that something in the system blocks the noise.
has anybody experienced that problem or - even better - any ideas about a solution?
thanks in advance
thanks in advance
