Bad sound from Realtek HD Audio
gargamel
Hey all,
I bought a new computer with this configuration:
  • INTEL G31/1600Mhz/asrock
  • Intel® Dual-Core E5200-2.53GHZ-2MB-800FSB/45Nm
  • Memory 2 GB Kingston
  • onboard Sound card: Realtek High Definition Audio
I installed Windows Vista Business x32 bit and everything is working properly except the sound card, I can hear music but it sounds so bad.
I have 2 front and 2 rear speakers that worked great with my old computer (also with onboard realtek sound card) so I guess the speakers are not the problem.
Let me tell you exactely how the sound sounds like:
I put Madonna, Fever song (which is a good one..)(MP3) and I bearly hear her voice... when her background vocals start screaming I can hear them bettter the the main vocal. It's like the front speakers and the rare swithced, but they didn't - from the Realtewk Audio Manager when I test the sound everything is ok.. I mean the front sound comes from the front speakers and the rare sound from the rare ones.
I also tried to change the speaker configuration from 5.1 speakers to stereo and to quadraphonic but the sound is the same - only background voices!
Does anyone had this problem before ?
I'm going to a lab to check this problem but before that I decided to write this post here.
I don't know if it Vista problem, Ddriver problem, hardware problem or software problem... any Ideas?
I'm desperate.. :(
Thanks,
Roy.
Hello Roy.
I have the same onboard audio (or close) and it works great for me. Try opening up the settings, and setting the rear speaker to the front speakers. That might help. Also open up the equalizer, and check the settings. Make sure that it is one of the preset settings. I would also check to make sure it is plugged in correctly. They are all colour coded so it should be easy. Let us know what works.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
Lordbob ,
Thanks for replying.
I tried what you suggested and the front still sounds like rare.
I also tried to use different speakers (I tried my earphones) and still rare sound...
In the audio manager panel there are 3 color lines: blue, green and red. the red is for the mic, the green and blue is for the speakers.
When I press the blue line a window pops up and I can set the type of speaker (rare, front, center, etc). Somehow I cannot set the green one which is the problematic one :confused: I mean when I double click it the window that should pop up doesn't... so I cannot set this one.
Can you set it in your panel?
Roy
On mine I can right click the tray icon and get the Realtek HD Audio Manager with tons of settings...
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
With the Gigabyte I get a nice display.
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
Hey Guys,
Maybe I diddn't expressed myself well...
I can open the Realtek Audio Manager.
The right side of this window has 3 lines (the back panel) red, green and blue (Techymike, You have 6 lines..).
When I double click the blue line the window in the image pops up (as described in my last post above)
BUT when I double click on the green one (in the image I circle it with red circle) the window doesn't pops up.
My Question is can you double click on every back panel line so this window pops up ?
Roy.
Well Roy, you cant click on any of them. The highlighted ones merely show where something is plugged in. Nothing else.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Hey all,
I'm desperate.. :(
Thanks,
Roy.
did you ever get that problem fixed with the sound, cause i was haveing the same problem it seems
.[/QUOTE]
did you ever get that problem fixed with the sound, cause i was haveing the same problem it seems[/QUOTE]
isaiah2013,
Just noticed your inquiry,
-Go to control panel
-click on realtek audio manager
- reset (default the environment and equalizer)
At this point, you can adjust for personal preferences..Hope this helps.
Alex
    H.P. Pavilion/ dv6985se notebook/ P/N FE11UA#ABA
    Intel 2 Duo T5750
    Quanta ver. 79.2E
    4 GB/2 slots DMM
    Mobile / Intel 965 express chipset Family
    Realtek High Def. Audio
    laptop
    15.4" vis
    Toshiba MK2552GSX (250.06 GB)
    Internal factory w/ outboard Transformer
    Factory burgandy
    1 input, 1 output
    F.O. single rotary
    Standard small w/o # pads
    Normal fiber.
    Keyboard standard 101/102 Main circuit Quanta 30CC 79.2E Bios H.P. F.59 Router, Netgear WGR614v8 Cannon MP250 wired printer Modem Motorola SM 56 Realtek High Def. Audio
