Creative HS Fatal1ty Gaming Headset Mic
Selmuir
Hey all,
I just bought the Creative HS Fatal1ty Gaming Headset and i cant seem to get the mic working. I think i know the problem but dont know how to solve it. Heres a picture of my sound>recording
The mic is plugged in right and is not muted. Please help
Thanks
Had the same problem but although I thought that the mice was plugged in, it wasn't. I really had to push very hard to get contact. Hope that will solve it.
Hey all,
Thanks
Windows 7 Forums this is vista forums.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
  • When Sound Blaster drivers and applications are installed correctly, it is recommended that you un-install them with the Windows Add/Remove Programs (Windows XP) or Uninstall (Windows Vista) wizard in Control Panel.
  • If you are using Windows Vista, it is recommended that you download and install the latest Windows Vista drivers. Do not use the installation CD-ROM disk unless the disk is labeled for Windows Vista.
To uninstall a device driver in Windows Vista, it is recommended that you use Windows Device Manager.
  1. Click Start, Control Panel, and then double-click Administrative Tools, double-click Computer Management, and then click Device Manager.
  2. Double-click the type of device, for example, Sound, Video and Gamer Controllers, that you want to uninstall.
  3. Right-click the specific device (for example, Sound Blaster X-Fi) you want to uninstall, and then click Uninstall.
  4. In the Confirm Device Removal dialog box, select the Delete the driver software for this device option and then click OK.
  5. Restart the computer
  6. When you are done uninstalling the device, remove it from the computer if desired.
If you have a Sound Blaster installation CD-ROM disk (Windows Vista edition), you can manually uninstall the Sound Blaster drivers by running its SETUP.EXE.
To do so, insert the installation CD-ROM disk. Close the Installation/SETUP wizard if the CD-ROM autoruns. Browse the CD-ROM disk, open \Vista\Audio\Drivers, and double click on the SETUP.EXE file.
Use this link and search for the correct driver based on the headset. I do not know if the headset is the HS-1000 or not as you did not list it. http://support.creative.com/KB/showarticle.aspx?sid=14186&h=13
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
