fishcharmer
I recently connected my computer to a 19" LCD tv and the picture is great but i don't know how to make the sound come out of the tv. Please help if you can. I have Windows Vista Home Premium 32 bit.
HDMI cable does not transfer sound. That is why DVI cable was invented, which takes the high quality video from HDMI, and adds sound. You'll need to connect a separate cable from your computer to your speakers.
DVI doesn't carry audio.
AFAIK, that's for use with a DVI-to-HDMI adapter.
And a very nice card it is too. I like mine. I don't use HDMI audio, so can't say if it works.HDMI cable does not transfer sound. That is why DVI cable was invented, which takes the high quality video from HDMI, and adds sound. You'll need to connect a separate cable from your computer to your speakers.
here you go one card that does...
Yea I'm aware of them cards, and from what I've seen on the net, to get the audio through HDMI, a separate cable needs to be attached, and I was thinking it might be why he's not getting any sound through the TV![]()
Norm
I'm pretty sure HDMI does, and with HDMI graphic cards, an extra cable needs to connect from the sound device to the graphic card so the audio can be carried through the HDMI interface.
