No volume control for Line In (Sigma Tel)
laffitte
Is there a way to control volume of the Line In ? I have Sigma Tel HD Audio Codec and when I go through all the control panel maze to get to it and click on 'Properties' there is no level control. Apparently Realtek must have a volume control (?). If the Sigma codec can't control the volume of Line In, can I change to a realtek or something else?
thanks
    dell inspiron laptop I1720
    inter R core TM 2 duo T5750 @ 2Ghz
    2038Mb
Hi laffitte and welcome to Vista Forums :party:
The audio controls are installed with the relevant audio driver, and it depends on what the manufacturer decides to include, although it is unusual for there not to be level controls for available input devices. You cannot change the driver to any other make as the driver software will not be compatible with the hardware. Here is a link to the Drivers & Downloads page for your laptop.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Thank you, thank you! - I was able to download a newer version of the Sigma Tel driver from the link you supplied (Dell Support) which has been improved to add input level controls. Problem solved!
    2038Mb
You're welcome, laffitte.
    Gigabyte IF233
